CEL With A/C on while on highway
Legwerx
Post by Legwerx »
Ok, so I just got done swapping a 2.0 block, with 2.2t heads, and a stock n/a 2.2 ECU injectors, etc.
When I am on the highway, merging (or doing 80) the CEL will pop on but, only with the A/C on.
Not sure what codes, haven't had time to check the codes yet.
Just seeing if anyone else has this problem...
Rick
1990 L Wagon
EJ20 short block, 2.2T heads, legacy turbo, stock 2.2 ECU. Full 3" turbo back exhaust, JDM AWIC, 8 psi.
Runs Great!!!
BSOD2600
Post by BSOD2600 »
Hard to say w/o a CEL... I was getting one a while ago during freeway driving that would come and go. Turned out my knock sensor was very loose.
'11 WRX Limited
'94 TW | R.I.P.
check the ECU for codes.
