F/S ej25 sohc heads
I was planning on putting them on my car but I just need the car to run for now.
I bought the heads with 66k on them, They came from a 2001 forester with a broken timing belt or they didnt set the timing correct. so the exhaust valves hit and need replace. I bought all the parts to fix the heads
stock 2.5 sohc heads with cams/gears/inside covers
2.5 valve covers
2.5 head bolts
new 2.5 exhaust valves paid $21.57 a valve =========$172.57 for 8 valves
new intake/exhaust valve seals $4.38in $4.95 exhaust===$74.64 for 16 seals
new valve cover gasket $13.95ea================$27.90 for 2 gaskets
new spark plug tube seals $3.17ea===============$12.68 for 4 seals
new valve cover bolt seals $1.98ea===============$19.80 for 10 seals
new Intake manifold gaskets $5.40ea=============$10.80 for 2 gaskets
Now thats 327.71 I paid in parts with tax
I also have the 2.5 intake manifold, throttle body, coil pack, upper wire harness, map, crank cam sensors
Now i spent alot for the parts and will take best offers either for heads and rebuild parts or everything.
Will consider trades Im looking for a vf39, aftermarket down pipe, up pipe flanges
Let me know
Tyson
ALSO THIS IS POSTED IN AWDPIRATES. You pay shipping if you want it shipped
I do take paypal
F/S ej25 sohc heads
94legacy2.2
F/S ej25 sohc heads
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
