There are 3 basic types of axle
Type 1: Female inner joint - USDM Legacy Turbo 91-94, USDM WRX 02-05
Type 2: Narrow male inner joint - JDM Legacy Turbo 91-94, USDM N/A cars (impreza, legacy, forester) 95-01
Type 3: USDM STi 04-05
These each corrospond to a type of differential
So, direct bolt-on as far as axles go (not accounting for gear ratio or mounting) would be:
91-94 USDM Legacy Turbo
02-05 USDM WRX
Which pretty much puts a huge restriction on the availability of LSDs
If you swap out the rear hubs to RS rears, it opens up the following:
USDM Impreza
Legacy GT 97-01
There are quite a few options for LSDs in here, as some RS's (00, 01 option) came with an LSD, as did LGTs
The above can also be accomplished by dismantling RS axles and attaching Legacy outer joints
In order to swap in a USDM STI rear diff (R180 LSD, for instance), you need to have STI inner joints. I have not seen any other inner joints that are similar, but I am going to be looking into the possibility of 300ZX inner joints, since they use the same diff
So if you have a set of STI axles, you can take off the outer joint, put on Legacy outer joints, and you're laughing.
I'm going to keep adding to this as I get more info, corrects and additions are appreciated
