I'm rather interested to see the common places between the SVX and the Legacy. The EG33 is basically an EJ22 with two cylinders tacked on.
Out of the Legacy World for a while...sort of
Manarius
Well, ever since about a month ago, I've been car-less and driving around a gas hungry Corvette. So, tonight I picked up a 1995 Subaru SVX LSi for a daily driver. I know it's not a Legacy, but I couldn't justify getting a AT Legacy when I could get an AT SVX for the same money. I'm still trying to get adjusted to driving a car that doesn't shake when you go past 75 or so
- quasi-mod-o
The EJ18E, EJ22 (E or T, doesn't matter), EJ205, and EG33D all have the same part numbers for rods.
Bore and stroke are the same on the EJ22 and EG33.
Jason is right, as far as the shortblock goes, the EG33 is essentially an EJ22 with two extra cylinders.
Edit: I was 99% sure about the b x s, but I just looked it up in the FSMs and I am right. And I know the rod part #'s are the same for sure also. So whoever was trying to put EJ22T parts in an EG33 was 1) not accomplishing anything with the rods and 2) doing something wrong.
Last edited by entirelyturbo on Sat Aug 18, 2007 8:19 pm, edited 2 times in total.
Hey, at least you still have a Subaru...
I really want an SVX...even though they go against most of my car-liking ideals (they look funny and are heavy), I still have a huge thing for them...
I definately see one with a 3.90 MT swap in my future...
and big congrats on the new purchase!!!
Well...how perfect...because the 6MT is a 3.90Splinter wrote:I wouldn't do anything but a 6MT in the SVX personally555BCTurbo wrote:I definately see one with a 3.90 MT swap in my future...
SVX is a 3.59:1 rear end. Also is rumored to be a R180. So a WRX 5-speed should be a drop in. 6-speed needs rear gears or possibly a STI differential.
From what I researched long ago (I had the SVX hard on for a while too), the Legacy pedals drop right in. A EJ flywheel is a bolt in. And the transmission crossmember was minor-to-no mods. No 5-speed console exists for the interior. And I don't recall if a off-the-shelf driveshaft from another Suby can work.
Ej22t pistons should drop in. Use the EG33 rods, but I seem to recall them being the same anyways.
Turbo 6-speed SVX. Prolly cheaper and easier then most would admit.
I'm thinking drag car! Get an EM system with launch control - tear out the insides, roll cage, my god that would be freaking cool...Lght up all four wheels in launch. You could lighten that thing up quite a bit by tearing the usual stuff out...but all that glass has to weight a ton. So do you bake driving around in those on a hot day?...
I saw one on Craigs list a while back that was two tone...Blue on the bottom silver on top....really sharp. Looked like a darn shark...
So why are these so cheap? Tranny goes south and there's no room in the engine bay to do much...
Oh have you ever seen the intake manifolds on these things. Really nice integrated logo dealy bop. Bit old hunk of metal...
Should be a fun project - Congrats...
For all that, make a speedster out of it. Remove the roof and the back seats, cover the back, sandblast the top off the windshield, and weld the doors shut.
Manarius
Do you bake? Not from what I can tell. Driving around on an 80 deg day with the sunroof open and windows down I was rather comfortable as long as I was moving. I'm still not a big fan of leather and that contributes to my heat rating.Adam West wrote:I'm thinking drag car! Get an EM system with launch control - tear out the insides, roll cage, my god that would be freaking cool...Lght up all four wheels in launch. You could lighten that thing up quite a bit by tearing the usual stuff out...but all that glass has to weight a ton. So do you bake driving around in those on a hot day?...
The 95 is OBD1, right?
I dig the SVX. I almost got one instead of getting the Forester, but I knew I'd never end up doing a 5 or 6 speed swap.
Manarius
AFAIK, it is still OBDI. Right now I'm trying to figure out if 230hp is enough to break rubber in AWD. I floored it in the rain today and I'm wondering if the car's AWD is working correctly....
- quasi-mod-o
Manarius
Oh no. It's AWD for sure. It has the pumpkin in the rear. The FWD fuse is not installed either. Sometimes it feels like it catches, other times it doesn't. I'm not used to driving a car with so much power. Sometimes I feel like I can break rubber on dry pavement and sometimes it feels like I can't. The car is equipped with a rear LSD, but I'm wondering if 230hp is enough hp to break three wheels free in the rain and enough to chirp them in the dry.BAC5.2 wrote:Did you buy an FWD SVX? That could be your problem right there...
I really need to do a gravel test, but I don't have any gravel to go to
Manarius
If I had a garage....Splinter wrote:Put it up on jackstands?
Do that on the street.
I've had my car on jackstands in the parking lot of my college before. No one cares.
It's a 3.545 with an R160 rear.PhyrraM wrote:SVX is a 3.59:1 rear end. Also is rumored to be a R180. So a WRX 5-speed should be a drop in. 6-speed needs rear gears or possibly a STI differential.
Pedals from an Imp or Legacy can be modified and combined with SVX parts to fit.
Modding and adding to the SVX crossmember is better than trying to mod the Leg crossmember.
For the console all you need to do is attach a leather boot to the bottom of the stock console.
A six speed SVX is now fairly easy, with kits produced by a member of subaru-svx.net. There are half a dozen that I know of, probably closer to 20+ in existence. I only know of two turbos, but there a handful of SC'd ones with two different systems.
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
Me and a buddy have done that, but built for AXing and hillclimbs, not dragging. We have the weight at about 2800 now. About the only weight left to lose is the fixed glass, and now that we have a cage we can start to lose some sheet metal.Adam West wrote:I'm thinking drag car! Get an EM system with launch control - tear out the insides, roll cage, my god that would be freaking cool...Lght up all four wheels in launch. You could lighten that thing up quite a bit by tearing the usual stuff out...but all that glass has to weight a ton. So do you bake driving around in those on a hot day?...
Last year at the Grassroots Motorsports $2006 Challenge we got it down to a 14.242/96 mph. We kept increasing the pressure in the tires, because it wouldn't break them free with a 2500-3000 TC rev. We figured to keep going higher to decrease the rolling resistance. I think by the peak afternoon heat we were up to 45psi and still not spinning them.
