I am searching for the best price on KYB AGX for 91 Legacy...I can't find the correct application.
Can someone point me in the right direction.
Which KYB AGX application for 91 SS
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
The answers are in the stickeys.
From memory, Prefacelift cars do not have a AGX application. You need to convert to post facelift specs.
Springs, struts, spring perches and tophats.
I'm sure one of the experts will chime in soon.
post facelift (or any other legacy) has no agx application per se either. You have to go with 93-01 Impreza stuff.
Same mounting points, same geometry, similar weight. There are no issues unless you have a wagon.
Call ground control directly and ask them which springs you should get to use with AGXes on a 1st gen legacy or impreza.
does it matter that its a 91 vs 92-94 for the Ground Controls?
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
I did not fing which Ground Control Sleeve application to use for my 91 SS in the Stickies...maybe I just missed it, but I read it a few times
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
