where is the ecu on my car
awdwagon
Post by awdwagon »
Hi
I know this is a really stupid question but where is the ecu localted on my 1991 turbo legacy?
tahiti350
Post by tahiti350 »
'90 sedan was located driverside behind the dash, above the fuse block. , ASSUMING, but '91 T should be the same....
awdwagon
Post by awdwagon »
no thats the TCM transmission control computer i think there is one for the engine under the passanger side floor board or something for the engine 2 completely differnt ecu's
PhyrraM
Post by PhyrraM »
Tahiti is correct.
It is above the fusebox. The transmission is also there. The ECU is held in with 2 nuts accessed from the fusebox hole after you take off the lower dash panel.
The ECU will have 4 plugs.
IronMonkeyL255
Post by IronMonkeyL255 »
Having just done a trans swap, I can say for 100% fact that it is tucked up behind the dash on the driver's side. It is actually just to the left of the TCU, and tucked away a little bit more.
Rio Red '91 Legacy SS
asc_up
Post by asc_up »
yes. i can verify for a fact that that is where it is.
it's a bit tricky to get to.
you probably read a hayne's manual and that's why you think it's under the passenger side floorboard. it's definitely not. i tore up my car looking for it under there. don't listen to hayne's at all for our cars lol.
adema2626
Post by adema2626 »
Its a b*** to get out... haha at least for me... or maybe i was just impatient so i ripped out the whole dash :)
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
IronMonkeyL255
Yeah. You have no patience. It really isn't that hard to get out once you pull the lower dash panel and fight with the wiring harness.
adema2626
Post by adema2626 »
IronMonkeyL255 wrote:Yeah. You have no patience. It really isn't that hard to get out once you pull the lower dash panel and fight with the wiring harness.
It is my curses... :)
IronMonkeyL255
adema2626 wrote:It is my curses... :)
I'm the same way with some things, so I know your pain.......
awdwagon
Post by awdwagon »
thanks
