Hi, I have a Whiteline 22mm Rear Sway bar that I bought on ebay about six months ago, and we, (my mechanic and I) tried to install it the other day, and it doesnt fit. Is this the right size or not. The auction stated that it would fit my 94 Touring Wagon. What size do I need if its not the right size, or could or should I replace the sway bar links as well. Thanks for any info you guys can provide.
Dan
94 Touring Wagon 163k miles
Whiteline Rear Sway Bar
94TurboWagon
Do you know the part number?
The right parts for our cars are:
droplinks (90-92):
BSR17 - 18mm
BSR17X - 20mm
BSR17XZ - 20mm adjustable
C endlinks (92-94):
BSR19 - 18mm
BSR19X - 20mm
BSR19Z - 18mm adjustable
BSR19XZ - 20mm adjustable (I think 18-22mm)
BSR19XXZ- 22mm adjustable (20-24?)
What about it doesn't fit? If it's too wide you have an 04+ STi bar, if it doesn't clear the spare tire well you have an Impreza bar.
droplinks (90-92):
BSR17 - 18mm
BSR17X - 20mm
C endlinks (92-94):
BSR19 - 18mm
BSR19X - 20mm
94TurboWagon
IronMonkeyL255
I am pretty darn sure they are interchangeable.
My '91 bar has bends so it just clears the spare tire well, not like what he is describing.
Rio Red '91 Legacy SS
