removing the auxiliary purge valve
macipusy
Post by macipusy »
My auxiliary purge valve has a broken nipple for the canister line... and air leaks like crazy...idles like crap too
Can I just remove the valve and cap off the lines...or should I get one from a junkyard?
any ill effects?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
If you can find one, it'd be good to replace, if not, you'd probably be alright with capping the lines off. The only thing I might do is put a check valve in the vent line going back to the tank, so in the event the cpc valve fails, you're not putting pressurized air in the tank.
kleinkid
Yes! He's back!
Post by kleinkid »
We missed you, vrg3. Do what is comfortable. Take care.
Thanks, dude.
Yeah, good to see again Vikash!
Thanks, Josh, it's nice to see the board's still doing well and has a lot of new members!
