5speed swap car wont start (not cracking over)
awdwagon
Post by awdwagon »
Hi
So i just finished the 5 speed swap in my 1991 turbo legacy and i cant get the car to crank over?? any ida's thanks guys
Splinter
Post by Splinter »
A bit more info would be useful
Chances are, you didnt hook up the neutral start switch to the clutch pedal, so the ECU thinks the car is in gear, thus wont activate the starter.
awdwagon
Post by awdwagon »
ok im reading the wrightup where the heck is my inhibitor switch located?
The inhibitor switch is in the AT tranny.
Don't hook the neutral switch up to the clutch pedal. It goes to the ECU.
If you read my write-up, you should be able to figure out what you need to do to get the car running, even if you don't put in the clutch start switch.
