FS: 1993 Legacy LS AWD Sedan-$950
Matt S.
Post by Matt S. »
1993 Subaru Legacy LS AWD Sedan
Trans: Automatic
Miles: 225,XXX
Vin # 4S3BC6536P7643945
Located in Mount Carmel, PA 17851
Had the following done within the last 20K miles:
• Timing Belt replaced
• Power Steering Belt replaced
• Water Pump Replaced
• Oil Pump resealed
• Valve Cover Gaskets Replaced
• Coolant system flushed and coolant replaced and ALL coolant hoses replaced
• Automatic Transmission flushed
• Power steering fluid drained and replaced
• Brake fluid lines flushed and fluid replaced
• Rear Brakes AND Rotors brand new
• Front and Rear Differential fluids replaced
• Tires less then 10,000 miles on them
• 4 wheel Alignment
• Water Temperature sensor replaced
• Oxygen Sensor replaced
• Intake manifold gaskets replaced
• Muffler replaced
• Oil and filter service just done
New fuel filler pipe
Idle Air Control Valve cleaned and gasket replaced
Tune up(plugs, wires, air filter, fuel filter, pcv valve)
Legacy Turbo grill(obviously not color matched!)
Misc. Vacumn hoses replaced.
I have a print out from W&L Subaru for any work they did on the car since I've owned it.
Car has hi miles(commute to work everyday) at 225,000 but runs and drives great. I averaged 26mpg city/highway. Car has All-Wheel Drive, 4-channel Anti-lock brakes and a driver’s side air bag, AM/FM cassette(needs antenna), power windows, power mirrors, power door locks, 2-way power moon roof, tilt steering, height adjustable driver’s seat, etc.. It will also be inspected through September of 2008.
$950
PM or email me.
Pics of the three rust spots:
1993 Legacy LS Sedan
208,000 miles young
dropdfocus
Post by dropdfocus »
Best of luck selling it! It will make an awesome winter car for someone.
If you haven't already tried it, you may want to place it for sale on Craig's List too (it's free!). That's how I sold my Kawasaki motorcycle.
http://harrisburg.craigslist.org/
Jason
Matt S.
Post by Matt S. »
Thanks for the tip!
I just listed it there.
-Matt
208,000 miles young
dropdfocus
Not a problem. Glad to help out a fellow PA'er.
Jason
