wilwood brakes?
macipusy
wilwood brakes?
Post by macipusy »
Hope these are good since I just impulse baught some on ebay.....I saw red ...look like 4 pot but little with pads and slotted rotors....maybe cross drilled....here is the link
http://i13.ebayimg.com/05/i/000/b8/90/db07_1.JPG
hope it works...
can someone tell me a little about these
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
Post by SubaruNation »
macipusy
Post by macipusy »
Was listed for 02 WRX...used item for 249 shipped....hope I just got a steal :P
maciek puszynski
16 WRX | 6mt | fa20
macipusy
Post by macipusy »
maciek puszynski
16 WRX | 6mt | fa20
macipusy
Post by macipusy »
I was searching and they look like these:
http://www.hopupracing.com/wi4redro02wr.html
4 piston rears.....is it possible to use the big rears as front calipers?
maciek puszynski
16 WRX | 6mt | fa20
jamal
Vendor
Vendor
Post by jamal »
they are not rear brakes.
I don't know how they'll effect bias, but I can pretty safely say not for the better.
macipusy
Post by macipusy »
So they are front calipers?
Are they an ok product?
My intention was to use these as front brake replacement
maciek puszynski
16 WRX | 6mt | fa20
n2x4
Post by n2x4 »
They're front calipers. Wilwood does have 4 piston front calipers, just not listed on their site.
They won't fit under 15" and some 16" wheels.
It's also said that calipers like these need to be rebuilt just about every year. They don't have dust boots around the pistons.
You did make a good buy, $250 is a pretty good deal. I'm just not sure it's the right upgrade.
SUBARUEHS Racing
macipusy
Post by macipusy »
If I just swap these Wilwood for my stocker front brakes...while upgrading to SS lines....is this a good upgrade...or will it really screw with the balancing while braking....to the point of inefficiency?
maciek puszynski
16 WRX | 6mt | fa20
macipusy
Post by macipusy »
What if I use the wilwoods for rears and get Brembo 4pots for thecfront? Better bias now?.....or just crazy talk?
maciek puszynski
16 WRX | 6mt | fa20
jamal
Vendor
Vendor
Post by jamal »
crazy talk.
The brakes on your car are good and I don't think you really need anything bigger unless you're planning on going to a lot of track days.
Stainless lines, better pads, and a fluid flush would do a lot of good. Possibly new dust boots on the calipers as well.
If you really want bigger brakes, the only thing I recommend is front Subaru 4-pots (like on the 06-07 wrx) and keep your stock rears.
They are an increase in heat capacity, pedal, feel, and they do not alter brake bias.
The only other things that can make those claim are stoptech bbks.
n2x4
Post by n2x4 »
Subaru 4pot and H6 2pot rears. That's the combo everyone talks about
SUBARUEHS Racing
jamal
Vendor
Vendor
Post by jamal »
there is no H6 2-pot rear. The H6 is the 00-04 Legacy rear disc with a solid rear rotor and 1-pot slider. I would keep the vented turbo rear over the bigger solid rotor any day.
he could also get the 2-pot 06 WRX rear brakes, but that requires an additional bracket, new calipers, new rotors, new pads, and is unnecessary in my opinion.
Let me say this again, more loudly:
there is nothing wrong with your stock brakes. If you insist on upgrading, get the 4-pot fronts and keep your rear brakes. That is the best option when considering price, bias, feel, and added heat capacity. Plus they look cool.
macipusy
Post by macipusy »
I totally get what you guys are saying....the thing is, I already purchased these....SO
should I sell them, or is it worth the try to see what the itty bitty 4pot Wilwoods will do to me Leg? If it's not even worth the time to switch them out, then maybe I'll sell them....
maciek puszynski
16 WRX | 6mt | fa20
Kelly
Post by Kelly »
Fuggit, I say run em!
You got big enough wheels already, and if there already purchased, all you really have to loose is a bit of time and a bottle of brake fluid, right?
Those calipers will squeek like hell. Ive seen a few people run them, and eventually take em off. There also was a bias issue to, but cant remember the fix. I think you swap in an STI master cylinder, cause your stock one will have a lot of pedal travel, or something like that.
Look on RS25.com, I beleive theres a few guys runnin them on there.
jamal
Vendor
Vendor
Post by jamal »
I would sell them.
