I am no longer the proud owner of this great car
I need $1500 so I am selling my EJ22T. NEVER boosted, Will not separate xtras
AC blows COLD! Kenwood CD, Alpine/kenwood speakers, everything works.
it has 160k, interior is clean, runs good, drives well and passes smog.
Saab intercooler
WRX coolant reservoir
VDO vision boost and oil press guages (match stock guages nicely green backlight too, oil wired but not plumbed)
WRX STI exhaust
K&N filter
I'm pretty good about maintainenance. champion copper plugs, has the good coil packs. new cv axle last year. brakes good, engine oil and filter regularly maintained, coolant changed, diff lube changed, brake fluid changed, trans fluid changed. etc
the bad:
dent right front fender
leaking radiator
cracked windsheild
drivers seatbelt stuck
Extras never installed:
Hallman Manual boost controller
HKS Fuel cut defender
Turbo XS H34 BOV
custom made 3" turbo down pipe
I may have good TD04 turbo, if I can find it.
new STI cats, oops think they got tossed.
drivers side seatbelt motor, track, sensors
seatbelt controller
drivers lapbelt
MAF sensor (new ones are $$)
I was going to relocate battery to trunk so there is a #4 wire aleady run, it could be used for a monster amp.
pics here: http://sfbay.craigslist.org/nby/car/431829027.html
email me and I'll call when I have a chance. kidwired@yahoo
located in norcal bay area.
