Help plz on rear diff breather?
how do I remove the white plastic breather on top of the diff with out breaking or cracking it? I want to take the back diff plate off to do a check on things and im going to put a coat of paint on it, but I need to remove that breather to get at the last bolt
IronMonkeyL255
IIRC, just pull on it. Maybe twist a little while pulling, and just use your hands, but it should come out fairly easily.
Rio Red '91 Legacy SS
