I took the shortblock, the resonator and the strut tower sensor/solinoids.
It still has the 3.9 LSD, a complete and un-cut turbo wiring harness, complete intake manifold, a turbo that is still very tight and a decent SS interior. Most of the panels, including the hood have minor to major dents. The scoop is cracked. The decklid and wing look good. The front lights and grill are bad. I forgot to check out the front bumper.
It looks like it was put in there because of cooling problems. Looks like a small accident took out the radiator. When the car was fixed a VERY wrong and too small radiator was installed. Semi-fresh silicon around the water pump and only 1 bolt in the T-stat housing.
I will be going back for the LSD and the turbo-spec harness. I wont have time till the weekend, so.....good luck!
