This block lost a piston and torn up a cylinder a little. $300 Has been honed, cleaned, and flatness check. The bad cylinder would probably clean up if you went with wiseco .040 oversized pistons. This block would be prefect for a sleeving if you wanted to go that way. It is also missing one oil squirter which you would have to find at a dealership.
bad cylinder
-Max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
