For those not from CO - this track is at ~6000ft ASL, so turbo times are about 0.5sec and 4+mph off sea level times (NA are about 2x that)
Anyway on to the results! 4 runs (it was packed!!)
-----60'------330'----1/8mi (et/trap)---1000'----1/4mi (et/trap)
1) 2.210, 6.456, 9.963/70.58, 12.972, 15.540/88.29
2) 2.119, 6.301, 9.792/70.83, 12.802, 15.364/88.38
3) 2.003, 6.203, 9.664/71.36, 12.653, 15.187/89.36
4) 1.994
I call that 15flat@90mph
Temp started at 75F and ended at 65F.
My 60's were 2.2/2.1 when I tried to launch at ~4500rpm, then dropped to 2.0/1.99 launching at 5500-6000rpm after rolling through the water box - I could do this consistantly now knowing what to launch at (and with some "wetted" tires).
I was REALLY happy to keep getting better and better times. There was a lot of down time between runs (30min-1hr) so I could cool off the A/W fluid between runs.
I was missing in 3rd gear around 5700rpm on Every run too, unfortunately. I could feel the car stop pulling/hickup then I'd shift to 4th at ~6000rpm. This definitely hurt my traps - bet they could be 91mph with a clean pull in 3rd.
Mods:
VF12 (14psi between 3,000-4,500 in 3rd - 11.5/12psi past 4500)
custom A/W IC
3" catted CES
UD Pulley
desnorkeled stock air box
WRX wheels/205/50/16 falken 451's
some suspension stuff that doesn't really matter....
-Chad
