CEL, MIL What ever you want to call it....
92LegacySpOrT
Post by 92LegacySpOrT »
So I just wanted to see what you guys think since you have had your Legacy's longer then I have had mine. Ok so I have done alot of work to piece this car back together. Such as head gasket set, the radator sub tank thing "sorry I don't know what it is called", the transmission "due to my lack of knowledge of subaru's. I blew a hole in the front diff was check the fluid wrong." So after all that I rewired the fuel pump "cause that's what roo's only told me to do." So that got it back and running. Then I decide to do the PCV and Fuel Filter man was that thing ever dirty. Also I cleaned the MAF after all that it helped the Legacy a bit. But I still had a bad missing problem and a funky idle let alone it missed as in popping type compression noise at WOT. So I rewired the TPS due to I noticed all the wire's were damaged on the connector. But that did nothing I did notice the harness Is damaged quite a bit. I have also Flash Codes 14,22,23,24,31,42,49 do you think that harness under the intake would be a great place to start?
Yeah probably.
92LegacySpOrT
Thanks for the input!
I just always like a second oppion form some one else thanks!
