Remote start
internetautomart
Remote start
Post by internetautomart »
I did a search but couldn't find anything that was clear to me about installing an RSKE unit.
Is there an illustrated guide here somewhere that I missed on how to wire it in?
I'm hoping to get it in before the temps really drop :nervous:
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
asc_up
Post by asc_up »
just follow the directions in the manual. they should have a website that you can go to and find all the right colored wires to tap into.
once i did that it was pretty easy.
stipro
Post by stipro »
SUBARU LEGACY 90-94
WIRE COLORS LOCATION
12 VOLTS CONSTANT----- BLK/YEL-----IGNITION HARNESS
IGNITION 1----- RED----- IGNITION HARNESS
IGNITION 2----- RED/YEL----- IGNITION HARNESS
IGNITION 3 N/A
STARTER----- BLU/RED----- IGNITION HARNESS
PARKING LIGHTS----- RED(+) -----@FUSE BX OR FUSE 6
DOMELIGHT----- RED/WHT(-)----- 16 PIN CONN ABOVE BRAKE
PWR DOOR LOCK ADD ACTUATOR IN DRV DOOR
PWR DOOR UNLOCK ADD ACTUATOR IN DRV DOOR *SEE DIAGRAM*
TACH SENSOR----- BLK/BLU----- @MPFI CONT UNIT BEHIND DRV DASH
BRAKE-----WHT/BLK(+)----- @SWITCH ON BRACKET ABOVE BRAKE PEDAL
HORN-----RED/GRN(-)-----STEERING COLUMN HARNESS
Hope this helps :)
internetautomart
stipro wrote:SUBARU LEGACY 90-94
IGNITION 3 N/A
Hope this helps :)
what is with adding an actuator?
isn't there one in there already from the central locking setup??
I don't think there is one that powers the driver door which is basically the switch for all the other doors. When you shut the door locked and it unlocks must unlock mechanically with the door lock not with a actuator.
internetautomart
ericem wrote:I don't think there is one that powers the driver door which is basically the switch for all the other doors. When you shut the door locked and it unlocks must unlock mechanically with the door lock not with a actuator.
I know on my old GL10 if I used the passenger door to lock, the others would lock too, that implies to me an actuator. I don't recall on the legacy though. (90 had no central lock, 92 didn't work right, 94 I haven't checked yet)
stipro
Post by stipro »
You have to put an actuator in the drivers door, which when activated locks/unlocks the rest of the doors. Passenger and rear doors have actuators, drivers dose not. I dont know why.
Manarius
Post by Manarius »
stipro wrote:You have to put an actuator in the drivers door, which when activated locks/unlocks the rest of the doors. Passenger and rear doors have actuators, drivers dose not. I dont know why.
It's the way a central locking system works. I have an actuator for one of our doors lying around somewhere at the apartment - along with a keyless entry system that I was going to put in the car.
justin the subie
Post by justin the subie »
if your putting remote start in a 5 manual trans dial in the neutral safety switch so your car dont drive away!!! :shock: i did it on my car.. works perfect.. cant remember what frigin wire it was but i could find out for ya.. i belive its lite green and yellow.. :-D
'92 TW "Hana" ej20tt obd1 <too many to list< sold :-( bought back :-)
SwedishChef
Re: Remote start
Post by SwedishChef »
Holy thread resurrection Batman!
I just thought I'd pipe in here a little on this topic for the sake of anyone else looking. After reading up quite a bit, here are some things I think I've learned:
• NOT all 94 Legacys came from the factory with the remote on the key... carID says only in Switzerland!
• The '92 FSM says those key remotes rely on a special driver's door handle which has a little glass window on it. My '94 does NOT have this.
• Presumably related is this thread, which discusses a method for programming the actual driver's door handle to unlock the car using a sequence of 'door handle pulls'. Did NOT work for my '94 L.
• Still have no idea where the ECU is for the door unlock controls... the '92 FSM says it's near the bottom of the passenger side a-pillar. Another thread said it's near the driver's kick panel.
[/list]
I purchased a universal Viper remote kit. It has a bunch of other possible features like hooking up the dome light, windows and horn, but I'll count myself lucky to get it to lock/unlock the doors. Also, since the "L" trim was the lowest in 1994, logic follows that ALL 1994 Legacys DO have central locking, but carID says the REMOTE was only an option for trims ABOVE the "L", so that explains the door handle trick not working and my driver's door handle not having the special 'window' for that remote.
For reference, I found some really useful links for wiring diagrams for other attempting this:
http://www.the12volt.com/installbay/ala ... /1981.html
http://www.modifiedlife.com/1994-subaru ... l-diagram/
Re: Remote start
Your 94 L should have central locking, my 90 L has central locking. Even the higher models didn't get a factory keyless entry though.
SwedishChef
Re: Remote start
Legacy777 wrote:Your 94 L should have central locking, my 90 L has central locking.
Oh yes I knew that ;-) and yes mine DOES have central locking.
Legacy777 wrote:Even the higher models didn't get a factory keyless entry though.
I'm pretty certain that's incorrect. For example, see attached pages from '92 Legacy FSM.
Binford
Re: Remote start
Post by Binford »
I have one of those keys. The LED lights up green when you hit the button. I thought it was just a built-in flashlight.
Re: Remote start
I guess I should have clarified I was talking about the North American Legacy models. The overseas JDM, EDM, & AUDM markets may have received the keyless entry, but the North American models did not.
The factory manual pages you provided are from the 92 Liberty manual.
Re: Remote start
Binford wrote:I have one of those keys. The LED lights up green when you hit the button. I thought it was just a built-in flashlight.
It is just a built in flashlight. The key in the pages above is different than the LED key we got in the states.
