Looking for some 550cc Injectors
I'm looking for some 550cc or bigger injectors that will fit in a EJ20G legacy injector rails they are from a 90-94 block. If anyone has any let me know. Looking for them to be used in good condition and maybe on the lower end the price range. Thanks
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
The Yellow STI injectors will fit LEGACY rails, that can then be swapped onto your manifold. I am 90% sure.
Also, you can modd cheap 270cc red injectors to be 550.....
Cut the tips off, or grind the tip off.
The way I did it, is grind the pintle cover off (the metal part with the tiny holes in them) and then purchase aftermarket pintle caps and press those back on to hold the o-ring on.
Pictures if I remember.
