i know i can get whiteline springs for around $275 shipped, but i really haven't researched struts and im looking for some informed opinions on whats good out there. i saw that has koni has some cartrige inserts that require converting to a bottom bolt in cartrige insert, which i can convert them myself, but koni's are pretty expensive. is there a good strut upgrade to be found for under $300? preferably adjustable so that i can make them soft for everyday stuff, but if i go for a canyon run or something i can stiffen them up a bit. ive seen some people use AGX and i might be interested if the price is right.
Oh, how can i tell if i have Air ride, since i know most of the suspention stuff out there isn't compatible with air ride?
