found this, what is it?
denver_whitest185
Post by denver_whitest185 »
I was fitting up my new front strut bar today, and i saw this. it looks like it was glued or something, and i'm 99% sure its a vacuum leak too
thanks
-Ted
1994 maroon Subaru Legacy SS sedan
1990 white Toyota Celica Alltrac - well modded :D
Bring the track to you
http://www.youtube.com/watch?v=mXfUbFR-x7g
denver_whitest185
actually, i did a little looking, and i looks to be the charcoal canister.
so, should i just delete it? thats what i did in my celica.
kleinkid
Post by kleinkid »
I wouldn't delete it. Just buy a used one, and make sure it is installed(plumbed) correctly.
Threshld1
Post by Threshld1 »
Some people have picked up N/A canisters without the secondary purge and removed the valve. Just make sure you plug the line into the intake resonator and remove the T on the line from #1 cyl going to the pressure sensor.
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
dzx
Post by dzx »
I have a n/a one on my car. But i didnt have one for a while and didn't really notice a difference.
///M
'93 Legacy SS - part out
denver_whitest185
well, i got a turbo legacy one from blackbart, so that will be going in there
if i was to delete it, it wouldn't be for performance value, just to save a little weight, and mostly to free up the engine bay. the one in my celica is 8-10lbs and sits right where most people like to mount oil catch cans.
tris91ricer
Title Whore
Post by tris91ricer »
But you could take it out, right?
Any good reason not to?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
denver_whitest185
its for emission control. thats its only purpose.
Dynamic Entry
Post by Dynamic Entry »
would our cars run stronger without it?
My area has pretty lax emission standards.......... hurray for catless exhausts!
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
denver_whitest185
no, IIRC all a charcoal canister does is let the pressure from the gas tank escape, but keeps the vapors. then it lets those vapors into the vacuum system when the car is started.
i think only people in california who have visual inspections have to worry about it being there. however, its not really doing any harm, so unless its broken and your cheap, or your stripping your engine bay, or your going to use that space for something else, might as well leave it.
New92
Post by New92 »
So if you delete this does that eliminate the need for the stupid canister purge solenoid valve located under the pass.side intake runner?
1992 SS 5MT
She's growing faster in her old age!
denver_whitest185
i don't know.
i just got a new one from blackbart. it actually runs a bit better now, but im guessing thats because there isn't a vacuum leak anymore.
yazmo
Post by yazmo »
so if i understand well that dont affect fuel consumtion like hayne manual say?
i dunno if mine work good i have stronf fuel odor and one of the symptombe is bad evap system!
