driveability issue. intermittent
mcbrat
Post by mcbrat »
runs great most of the time, other times, runs like poo.
when taking off from a stop sign, it'll bog down,sputter, stutter,etc...
I did some searching on the forums here, and found something about a pressure sensor...
then this afternoon when it was in a "fit", I heard a slight clunk, and it was back to running great again...
thoughts?
03 Baja Sport
09 Forester XT Ltd.
82 Brat - Toyota Solid Axles and 36's
Can you describe the 'clunk'?
mcbrat
Post by mcbrat »
beatersubi wrote:Can you describe the 'clunk'?
like something shut or opened.... with force
03 Baja Sport
09 Forester XT Ltd.
Can you give an approximate vicinity of the origin of said 'clunk'?
mcbrat
Post by mcbrat »
beatersubi wrote:Can you give an approximate vicinity of the origin of said 'clunk'?
after much digging through the posts here, I believe it to be the wastegate sticking open, and the "clunk" was it going shut....
03 Baja Sport
09 Forester XT Ltd.
Arctic Assassian
Post by Arctic Assassian »
astounding deduction watson!
Kickin' it old-school.
mcbrat
Post by mcbrat »
I oiled up the wastegate shaft, and it seemed to help a bit , but I believe it's the pressure sensor....
03 Baja Sport
09 Forester XT Ltd.
