hey will those swap straight into the EJ22t Block? If so how much for the crank, and what grade are the pistons A or B? If B I'm also interested. Thanks
The crank and rods are likely the same part numbers as an ej22t. If not EXACTLY the same, they are dimensionally the same.
The pistons are a smaller bore than an ej22t and are not compatable.
