Grinding noise, center diff shot?
TurboBeater
Post by TurboBeater »
I just finished putting in a 5MT from '02 WRX. Only thing left to hook up is the driveshaft. I tried driving it around the block just to see if it works or not, I figured the center diff should lock and allow the front wheels to be driven.
So it works and sounds fine under light throttle, but give it more and it makes a grinding/ratcheting noise and feels like its slipping? It doesn't make any noise when the front wheels are off the ground. Gear oil level is ok. Is this normal?
TurboBeater
Oh yeah, it does this in 1st and 2nd and reverse (didn't try the rest).
