total front wheel bearing failure
apparently my right front wheelbearing has failed so badly that the rotor is sitting crooked and rubbing against the caliper bracket.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
That happened to me on the drivers side. I picked up a replacement hub from 7th Ave in Fargo.
the discs are totally trashed. should have been replaced a LONG time ago.ericem wrote:wowa!!!!!! Time for a new hub and bearing and brake bracket and possibly a disk!
on the plus side diagnosing this problem has helped me become very quick at changing brake pads.
when the wheel is on the car and it is down on the ground you can see that the wheel has a ridiculous amount of positive camber.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
