ok i just got my set of manual belts from canada and am installing them, in the process of getting rid of the sholder belt on the drivers side i disconnected the harness that goes to the rear door (the 6pin connector) and the door side managed to get in the way of the rear door and now i have no connector left so i need to know what wires go where.
The first pic: It bolts inside the bottom of the b-pillar. There should be a threaded hole there.
The second pic: Slide the drivers/passenger seats all the way forward, below the center arm rest, feel through the carpet for a bolt hole and cut it with a knife/razor blade. However you may want to pull the seats, and flip up the carpet to find the hole.
