how do i drain my coolant? what is the best coolant
Front, Top, Air, Water.
LEAVINALEGACY93
Post by LEAVINALEGACY93 »
as the title says , i need to no how to drain my coolant , as it looks pretty diluted n dirty, i have a 1992 legacy turbo 5spd
thank you
next what is the optimum coolant to use? redline water wetter, justice bros radiator cooler, dei radiator relief, or any others you use
thanks
Imprezive
Post by Imprezive »
There is a Wing Nut type screw thing on the lower part of your radiator's left plastic endtank. Just un screw that all the way. (You might want to make sure your car has had adequate time to cool off)
If your radiator is in good shape you don't need any of that water wetter crap.
I would either go with one of the following:
1. Pre-mixed Anti-Freeze/Water solution. (Example: Prestone)
2. Mix it yourself Anti-Freeze & Water with a coolant system lubricating agent of some kind.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
