Installed a boost gauge - few questions and picture requests
Posted: Wed Nov 28, 2007 2:51 am
by denver_whitest185
its a greddy 60mm, and i think i'll install it on the A pillar (i think leaving it taped to the dash is really ghetto :P).
i read about the CRX and GC pillar pods, but i still haven't been able to find the pillar pod i need. i already searched a bit, but couldn't find anything. does anyone know of a site that has a 60mm single pod that will fit well?
If not, does anyone have any pictures of a pod installed with a band holder like this?
http://www.greddy.com/img/PHP/products/jpg/1088.jpg
How about some other install pictures for ideas? i was thinking it would go well in that vent on the left side of the steering wheel. i normally don't like A-pillar pods, and i have a custom pod on my alltrac, so maybe a couple of ideas might give me a clean looking creative way to install it.
My alltrac for example
http://i42.photobucket.com/albums/e344/ ... 0009-7.jpg
I can do some fiberglass work too. i would do something similar to this for the vent if i decided to run it there
http://s42.photobucket.com/albums/e344/ ... d%20molds/
-Ted
Posted: Wed Nov 28, 2007 5:47 am
by All_talk
Here's my setup...
Gary
Posted: Wed Nov 28, 2007 6:11 am
by beatersubi
Nice. Clean.
What boost guage is that? How are those affixed there?
Posted: Wed Nov 28, 2007 7:14 am
by All_talk
beatersubi wrote:Nice. Clean.
They are VDO gauges. Custom tube mounts machined into the bezel and lense.
Gary
Posted: Wed Nov 28, 2007 7:20 am
yeah, i saw your set up when i was searching. its very creative, but i can't think of a way to apply your idea without coping it straight out, which i would feel like im devaluing your work.
how about some info on a 60mm single a-pilar pod. keep the ideas coming, but i really need a pod quickly.
Posted: Wed Nov 28, 2007 4:31 pm
by All_talk
Imitation is the sincerest form of flattery. :)
Center of the tach is a very good location, easy to see, blocks nothing. I have seen other mount a boost gauge off the column so it sits in the same line of sight. Put it in a clean little pod or mount and it should look ok (and a LOT less work :P ).
Gary
Posted: Wed Nov 28, 2007 7:13 pm
http://www.optionsauto.com/prodinfo.asp ... =GW-20-434
so, would this work as a quick solution till i make something a little more discrete?
Edit: never mind - 2 5/8" is around 66mm, where 60mm is around 2.4" so that opening will be too big :(
Posted: Thu Nov 29, 2007 9:15 pm
so i ended up getting a good deal on a HKS ring gauge stand, so that will be its temporary home
http://www.hksusa.com/images_products/1334.jpg
still couldn't find anything that would work as an A-pillar pod other than a "universal" one, which would probably fit really crappy.
so far, my ideas for a custom mount would either be in the vent to the left of the steering wheel, or in the cluster in front of the RPM gauge like All_talk has his. Any other ideas or some pictures of how others have mounted theirs?
Posted: Thu Nov 29, 2007 9:26 pm
by 555BCTurbo
denver_whitest185 wrote:so i ended up getting a good deal on a HKS ring gauge stand, so that will be its temporary home
Devan told me that a 90-91 Honda Civic DX pod works...and he has one in his car and it even lets the seatbelts work...without modification!
Posted: Thu Nov 29, 2007 9:31 pm
i haven't been able to find any CRX or Civic DX single pods in a 60mm size though. ive only seen 52mm
Posted: Thu Nov 29, 2007 9:41 pm
by 555BCTurbo
denver_whitest185 wrote:i haven't been able to find any CRX or Civic DX single pods in a 60mm size though. ive only seen 52mm
Ah...I missed that you had a 60mm gauge...
Yes, that could be a bit of a problem...
I wonder if there is enough material on the Honda pod to bore it out to 60mm?
Posted: Thu Nov 29, 2007 9:49 pm
that crossed my mind, but unless i could measure and verify it beforehand, i wouldn't want to spend money on it.
Posted: Thu Nov 29, 2007 9:55 pm
by skid542
I mounted my gauge in the right center vent. This allows me to keep the left one which holds the up/down adjustment for the airflow. It is off the side a tad but still easy to see. I also put it in the right side as opposed to the left because as I turn the wheel, my hand would cover it up if it's in the left vent.
I will try to get you some pictures tonight.
Posted: Thu Nov 29, 2007 10:43 pm
by asc_up
skid542 wrote:I mounted my gauge in the right center vent. This allows me to keep the left one which holds the up/down adjustment for the airflow. It is off the side a tad but still easy to see. I also put it in the right side as opposed to the left because as I turn the wheel, my hand would cover it up if it's in the left vent.
hmmm that's an interesting idea. i really wanna see these pictures now.
Posted: Thu Nov 29, 2007 11:28 pm
by Trace
i bought a 89-90 crx single gauge a-pillar pod from glowshift on ebay, it holds a 2 1/16 (52mm) gauges which was a perfect fit for my autometer 2 - 1/16 boost gauge. for $6.99 its not bad at all.
The crx pod maybe seem a bit wide at first but a heat gun + 10 minutes of blowing will make it fit like a glove. i'll post pictures sometimes later
Posted: Fri Nov 30, 2007 3:59 am
by skid542
It is definately not as easy to see as a pillar gauge or the ones mounted in the gauge cluster. But it is pretty nice and provides a good clear view with a quick glance. You can also just make a false facing to stick on with some magnets if you really wanted to keep it sleeper. You will have to trim the vent ducting a little but running wires to the ashtray is super easy :).
Posted: Fri Nov 30, 2007 5:33 am
by beatersubi
I have mine mounted in the center of my tach. It doesn't block anything there, and I can check it at a glance along with my other gauges. But then, I'm not a big fan of pillar gauges.
skid- I like your setup. Have you considered a gauge angle mounting ring? What did you use to fill the hole?
Posted: Fri Nov 30, 2007 5:40 am
very nice. however i think those vents are a too short, so i still think that the left side vent will be used.
i got an idea from a friend on a way to do it better.
http://www.imageartstudio.com/justjoe/images/stri2.jpg
http://www.imageartstudio.com/justjoe/i ... e-wip1.jpg
http://www.imageartstudio.com/justjoe/i ... e-wip2.jpg
thats PVC pipe. i'm thinking a custom fiberglass "plug" of sorts for the vent, with a small piece of PVC like this epoxied to the back of it. after being smoothed, primer'd, and painted would look pretty wicked.
Posted: Fri Nov 30, 2007 6:50 am
by Trace
Posted: Fri Nov 30, 2007 7:28 pm
denver_whitest185 wrote:very nice. however i think those vents are a too short, so i still think that the left side vent will be used.
That's pretty sick looking!
Not sure if we have much room in the dash though for something like this.
Posted: Fri Nov 30, 2007 9:06 pm
by skid542
Beatersubi - Thank you, I'm pretty happy with it. I have thought about angling it but it's still very readable and I just didn't feel like messing with it. The back is just a piece of balsa wood that I cut to shape to use the screw hold downs of the vent. I then rienforced the back with some carbon fiber. Little spray paint later and viola! The big thing is I want to keep my car very stock looking from the outside and I can make a fake front very easily.
Denver - That is a slick setup and looks nice. I do doubt that there is room in dash to make that work smoothly. But that one application does look nice.
Posted: Sat Dec 01, 2007 5:48 pm
by mgroshong
Posted: Sat Dec 01, 2007 11:30 pm
by BSOD2600
Here's mine.
