I'm pretty well interested in a set of 16" Motegi MR7's or FF7's. The particular set I'm looking at is 16x7+42. I did a quick search just for Motegi, and the MR7 was very briefly mentioned in this thread...
...that they would fit, but nothing specific was mentioned. The Motegi site also says they will fit... but I'm not quite inclined to believe my car is terribly close to stock. I'm running Tanabe Sustec Pro adjustable coilover suspension, allowing for camber and ride height adjustments... so if this will make any difference, I'd like to know. lol
Thanks, and sorry about the redundant thread... I'm still having trouble wrapping my mind around the wheel choosing process.
Well, the wheels aren't going to be rubbing; the tires are. Depends on what you run. A 205/40 probably won't and a 235 probably will. Regardless +42 isn't enough offset and you should find a wheel in the 50-55 range.
In my personal experience, a 205/55-16 was the largest tire I could run on stock 93 struts with +55 offset 16x6.5 wheels. They were very close to both the fenders and the struts.
I switched to STi struts and have more negative camber. That means more room on both sides of the tire. 225/50-16s on 16x7 +53 wheels rub the fenders slightly.
*sigh* Finding wheels that work and suit my taste is hard. Thanks guys.
