Suspension interchangeability??
WagonMadness
Post by WagonMadness »
Hello everyone, i just bought a 93 legacy wagon and i noticed that the right rear lateral link is bent. I tried searching on here and nasioc but could find anything about if the links are interchangable between impreza's and Legacy's. If anyone knows could you let me know? turns out it is easier to find impreza parts then legacys.
~Scott
93 subaru legacy wagon
97 Subaru Impreza (g/f's car)
88 chevy Camaro
jamal
Vendor
Vendor
Post by jamal »
93-01 Impreza, 95-99 Legacy, and 02+ impreza wagons all have the same lateral links.
I also happen to have a set of front lateral links that are $15 shipped.
WagonMadness
Sorry dumb question are the front and rear lateral links the same? it is the one most rearward that is bent on the RR. If it will fit pm me about shipping on how you would like payment. thanks
~Scott
88 chevy Camaro
If you don't already have one, and would like a rear sway bar, then it'd be a good time for you to find a pair of those lateral links w/ swaybar endlink tabs.
WagonMadness
i'm not sure if it has one or not i will have to check, just got it and didnt really think about that before i bought it. thanks for the idea. well i will check tomorrow. what else is needed for the swap? all sway bar chassis mounts, end links, and sway bar. anything else?
88 chevy Camaro
Ya, all that, and the lateral links, of course. There's a writeup on it here. I think it might be stickied at the top.
Look for a 95-99 outback. I found that they're the most prevalent in junkyards and they all have a rsb.
Oh, and welcome :D .
jamal
Vendor
Vendor
Post by jamal »
yeah, front and rear are different. The inside rear bushing is wider to accept a cammed bolt for toe adjustment and on cars with rear swaybars there are mounting tabs for the endlink.
