1991 Legacy Wagon, N/A from factory.
I put in EJ22"T" motor, minus the "T" using the N/A intake manifold and misc changes to make it work.
On the 14th I'm pulling the engine, swapping the crossmember, fixing an oil leak that only occurs when the engine is cool (possibly the oil pan) and some other random stuff here and there; here's me documenting it starting tonight with photos.
I did a test fit of the turbocharger mounting location (again) since my samco intake hose I ordered today was not going to be here till well after the allotted time I had available; so I kept the hose on order and I'm just dealing with it by looking for other solutions, may have to pay a trip to NAPA and pickup some bulk hose and crap...
So, I started off by not taking pictures, I took the mounting bracket for the up pipe, the turbocharger, some wire and such and wired the thing in place using the oil drain pipe as sort of a support...
Well part of the problem has been that I didn't know how I was going to connect the turbocharger to the MAF box, I figured I could cut my standard N/A intake up and probably make it work but I knew I'd be an inch short (or so). Long story short is that I had to go pay mother nature a visit, and while I was petting my cat (who insists she be in the bathroom when I am) and making a deposit to the throne gods (it's where I do all my best thinking) I saw this gem...
Black bottom already removed. I went "hey! coffee cup mod!". and that solution was partially solved. I used to use it to hold my toothbrush on the bathroom counter.
I fucking hated working for this company, too much political crap, needless to say this "gift coffee mug" that everyone received from a merger of STL and TestAmerica (two months before I left) was the best thing that I've ever received from them.
Purdy with all that plastic shit removed (the can is metal, pretty light gauge but it'll do)
Fits like a gem, now I just need a 90* rubber hose elbow with an ID of 3.25" to make it work.
IAC on the right, breather from crankcase in the center. the rubber it's mounted in is tough and cracking (that's a serious bitch to remove. I'll have to figure something out, probably rotate it 180* and use a different hose than stock to connect it to the top inlet on the turbocharger.
If my rigging is right, this is the approximate clearance to the manifold, which leaves me just enough room to run a 5/8"s coolant line for the IAC underneath the turbo inlet and around the outside near the strut tower to plug into the output side of the turbo.. since I'm using the N/A headers I'm sort of screwed here, they don't have the flapper valve (or room for one) to prevent air from flowing out of the headers when on boost and back into the turbo inlet... Hopefully this will work.
turbo inlet on top left with boot removed, IAC on bottom right, this is just a different view to see how tight the fit is.
I've had this plugged off the last two years (hose pointing downwards coming off of the heads) I believe it's either a feed or return line for the turbocharger, hopefully I haven't wrecked anything by not having this hooked up to flow. So far so good.
Here's the directory of everything, these were the highlights, some of them are just for my memory.
http://www.thelostdays.com/public/car/120507/
measurements I took all are expressed in Outer Diameter (OD) unless otherwise specified; most of these are approximate not exact... may be helpful to someone else...
AWIC
Inlet: 2"
Outlet: 2.875"
Turbo Outlet: 1.75"
IAC Inlet: 0.550-0.625"
MAF Outlet: 3.25"
Coffee Cup Inlet: 3.25-3.35"
I'll update this as soon as I have more to put here. any comments/etc are appreciated.
