I have a set of Uniroyal tiger paw Touring all season tires that has about 60% tread left, its not bad for a all season on dry and rain but it doesn't perform very well on the snow even with only about 1-2 inch of snow on my 94 SS. it started to slide when i turn into a corner about 30 kph. And my ABS won't even turn on when I brake hard at about 10 kph. the whole car just slides like its on butter untill it stops. At first I thought my ABS is broken but the indicator light shows no problem and at higher speed the ABS does come on. The real problem is that I'm planning to go up Whistler on Dec 19th and i'm wondering if a new set of snow tires are necessary or it is enough if i put a set of snow/ice chains on those all season tires?
I've never driven a car too much on snows so I don't have much of a clue ><. but it sure was fun doing donuts on my SS. too bad the tires are crap or I could go faster without much skidding
Snow/Ice chains questions
internetautomart
Blizzaks are definitely recommended.
though a little research and you can find an A/S that will do great in the snow too.
either that or just learn how to drive with what you have. AWD may inspire confidence, but it also tends to advise stupidity.
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
Although not a snow tire I will HIGHLY recommend Dunlop Sport A2 as a great all around tire. They have dry better traction than most summer tires and better snow traction than most all seasons (thats not saying much I know). They also have pretty stiff sidewalls, great treadwear and are easy to find
