Ok so I notice last night as I pull into the drive through at Steak N Shake that my right front ball joint is still popping when I brake hard enough. At least, I suspect it's the ball joint. I did replace the axle up there a few months ago so perhaps the caliper is loose? Or even the axle.
Also the sway bar bushing is rotting, but there is no metal on metal contact at this point.
Looks like I will be back under there if I get the chance this weekend.
Thoughts?
Ball joint popping...still??
91 SS Pearl White
>Apexi Power Intake, HKS 3" Downpipe, Saab TMIC, Blitz SS bpv, STi Shifter and Bushing, WRX Suspention and Clutch, Whiteline RCA Kit, Whiteline Steering Rack Bushings (sport), Ghetto HoodScoop
yes it pops when I brake hard enough and then again when I let off. Some one said they removed their swaybar link when they chaned ball joints and positioned the link by jacking up the control arm. I did the same. They then stated that the link was loose and come to think of it, it looked a bit lobsided when I put it all back together. Could be part of it.
So, ball join fitment and castlenut, sway bar link and brake caliper (mount and slide)
Now if it would only stop sleeting....
91 SS Pearl White
thanks but I have no monies till...who knows. I am going down to the shop tonight or tomorrow and I am going to use my stringer impact gun on the bolts. The one I used will barely remove lug nuts at its highest torque...
91 SS Pearl White
I'll see what I can do. My bad ass job became more of an internship which is all right except I havent had a paycheck in over 3 1/2 months... SO, I'll try. Thank you.
91 SS Pearl White
