Heat wrap on Headers?
BXSS
Post by BXSS »
I got a set of stainless steel E/L 4-2-1 turbo headers off a well tuned EJ20K.
These things were on the 20K without any form of heat wrapping.
Should I heat wrap them when I try them on my car, or should I leave them the way they were on the other motor?
I heard that heat wrapping helped to crack BORLA na headers (but it seems like looking @ those caused cracks too), but these have slip joints in 3 areas that should allow for some expansion w/o cracking.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
ciper
Post by ciper »
Most everyone will agree that coated pipes are far superior.
For the price however I think exhaust wrapping is a wonderful thing. Most of the cracking issues are with cast parts rather than SS parts. Just make sure to buy the spray can of sealant so the pipes last longer.
BXSS
Post by BXSS »
Yeah, I believe ceramic coatings are better too but I want to be sure this mod makes the car quicker before I spend money on a coating ($175+ @ Swain coatings here in NY -? if they will work with a used part) for it.
I have DEI heat wrap & heat wrap paint just laying in the garage so using them would be free :)
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
ciper
Post by ciper »
I say wrap the headers and up pipe but nothing else. Make sure to have 50% overlap so every area has two layers of fabric. Also get the wrap really wet before applying it (squeeze out extra water).
When you say heat wrap paint do you mean the sealing spray that "sets" the wrap and makes it hard?
BXSS
Post by BXSS »
Yeah its the silicone spray that is supposed to help to keep the wrap from rotting...
I wonder why these headers were not wrapped by the guy in Japan who bought them?
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
206er
Post by 206er »
some say to leave the first 3" or so of primary bare. I dunno about that. I'd go ahead and wrap em if you have the stuff lying around. if they crack you can just reweld it.
Aerotech
Post by Aerotech »
It will probably only last you about 1.5 years... the exhaust is the lowest part of the front of the engine, my wrap got worn away in short order by curbs, snowbanks, and general road debris. Once you lose a section, the whole thing starts to unravel.
Jerry
ciper
Post by ciper »
You must not have used enough sealant on it if it started to unravel. I think most cans recommend at least 3 coats!
BXSS
Post by BXSS »
I wrapped the headers this weekend - they came out nice...
I also had a problem with ripping heatwrap on my Impreza.
I was playing in the snow/ice & snagged a 6-8" section of heat wrap on the OEM "y"pipe.
I'm going to buy a 4x8' section of 1/8th" aluminum & make skidplates for the Impreza & LSS to avoid that problem this winter.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
bmxpunk
Post by bmxpunk »
What heat wrap did you use? I am coating my TS headers/ uppipe inside and out but I was going to wrap over them as well.
I also got a skid plate for my car.
2011 Mini Countryman S All4
1970 Honda Ct90
BXSS
Post by BXSS »
I used DEI on my headers & OBS's UP & DN pipes in back in '04 & its is still hanging on (used DEI's silicone heat wrap coating/paint too).
I used DEI on the Y-pipe & a scrape caused a tear, but with a skidplate all will be good.
I have to get/make a skidplate soon as I have a Canton Billet oil filter that is LONG & sits about even with the bottom of the "Y" pipe.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
createnew
Post by createnew »
How many feet of that heat wrap do you need? I got a 25' X 2" roll for mine...
BTW I haven't put these on yet, but I got an awesome looking header and up-pipe combo that looks exactly like agancy power's header. The best part is, it was son;y $140... shipped!!
Compared to the agency power's $560 price tag or borla's similar design header for about $700...
Yellow '01 Kaw. ZX-7R (SOLD) :(
Gold '88 Starion ESI-R (Drift Project)
Brgndy '92 Legacy SS, Agency Power Style Headers and Up-pipe (ebay, don't stay together), Underdrive Pully, 5MT conv, mod'd WRX cold air intake and short shifter, 12.5 lb fly
ciper
Post by ciper »
Remember that you are supposed to have quite a bit of overlap. When you are finished the entire pipe should have at least two layers of wrap in every area.
scuzzy
Post by scuzzy »
ciper wrote:Remember that you are supposed to have quite a bit of overlap. When you are finished the entire pipe should have at least two layers of wrap in every area.
I've been told (and instructions say the same) that 1" wrap should have no more than 1/4" overlap, now that being said, achieving that in every single spot is a bit difficult, sometimes you wrap more in a specific area, never the less.
here's the result from my header wrapping:
I sanded down the cross pipe and up pipe, painted them with VHT and cured them in the oven at 200F for a while, then wrapped them with 25 foot of 1" wrap from DEI; I came up a little short (driver side cast iron header thingy is using some old wrap). Used stainless steel ties you can get at any Harbor Freight Tools store.
#82 M4 TRSCCA Rallycross
BXSS
Post by BXSS »
Nice job.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
scuzzy
Post by scuzzy »
BXSS wrote:Nice job.
It is nice, I can put my hands within 1" of the primaries without getting burned, you can definitely feel the heat; but it's not too hot to be so close.
tahiti350
Post by tahiti350 »
biggest problems I've seen with the wrap is split pipes (embrittlement) due to the heat the wrap retains. this was on new uncoated steel tube headers (small block chevy). I had 2 sets in a row that basically shattered near the collector within 3 months of install.
The header wrap voidd the warranty... :x
scuzzy
Post by scuzzy »
tahiti350 wrote:biggest problems I've seen with the wrap is split pipes (embrittlement) due to the heat the wrap retains. this was on new uncoated steel tube headers (small block chevy). I had 2 sets in a row that basically shattered near the collector within 3 months of install.
Well. Mild steel is fragile stuff. My down pipe was originally ceramic coated and heat wrapped and after about a year of use (and a year of sitting in my living room) the wrap had held water so well (since the down pipe doesn't get nearly as hot as the primaries do) that the mild steel had started rusting THROUGH the ceramic coating.
It took a lot of sanding to get rid of the rust, and even then I could see fracture lines in the surface. I took it to someone to have the O2 bung welded in and he informed me not to wrap it, so I just sprayed it with VHT paint and left it at that.
I wouldn't wrap anything other than stainless steel or cast iron - but even cast iron holds heat very well. Mild steel however is pretty fragile stuff.
tahiti350
Post by tahiti350 »
Just caught the Stainless Steel part, should be okay for a while, but will still embrittle eventually. Cast iron, now that's a different story altogether
Adam West
Post by Adam West »
Had a long email thread with Jeremy at Crucial Racing about not using heat wrap on coated pipes as it 1) overkill 2) holds water and which destroys the coating and rusts the pipes...
"DO NOT wrap the downpipe! One, yes, it's total overkill. But more importantly that wrap will probably destroy the coating and it might cause the pipe to crack. It's just too much heat retention. The coating is already more effective than wrap is, and doubling up like that is just too much and can cause metal fatigue. Even the companies that make the wrap specifically say not to wrap parts that are already thermally coated for that reason. And wrap is extremely tough on whatever is underneath it because of how it traps moisture and starts to eat its way into the metal... it'll eat through the coating in the same way I'm sure."...
http://www.crucialracing.com/products/
dirtyhandssubaru555
Post by dirtyhandssubaru555 »
the only problem i have ever heard of is from people getting to many layers/to thick of wrap and it causes hot spots on the pipe and there for the pipe fails, i have never heard anything about moisture but im sure it doesn't help
my girlfriend finaly found out that i spent more money and time on my car then her. she was kind pist to say the least.
92ss, tdo4, wrx stage 1 clutch and 9.5 pound flywheel, sti springs, k&n panel filter, desnorkus
86 gl hatchback rip
87 gl10 rip
coclodile
steel tube
Post by coclodile »
[url=http://www.steel-pipe-tube=manufacturer.com]steel tube[/url] is very important .galvanization also very important
94SS_Canada
Post by 94SS_Canada »
I didnt Even Seal my wrap, but i put enough clamps for it to last through WWIII
FastRust
My exhaust manifold has been wrapped for two years without any spray sealant, and it has been fine. If the car sits a lot I can see how it will hold moisture, but if you drive the car daily there won't be moisture in it. It doesn't take very long for anything to burn off, like coolant, lol.
When I think about it, the silicone spray lends me to believe that moisture will get trapped under there even worse, since it will have a hard time getting out, verses plain jane header wrap.
