boost gauge and understanding vacuum reading
dirtyhandssubaru555
Post by dirtyhandssubaru555 »
what kind of vacuum reading should i see at an idle? if you have a vacuum leak would you see more or less vacuum? i was told use a vacuum gauge to tell what kind of gas milage you are getting or help you to have better gas milage.
my girlfriend finaly found out that i spent more money and time on my car then her. she was kind pist to say the least.
92ss, tdo4, wrx stage 1 clutch and 9.5 pound flywheel, sti springs, k&n panel filter, desnorkus
86 gl hatchback rip
87 gl10 rip
You should see about 19 inHg of vacuum at idle. A vacuum leak on our cars typically results in an unstable idle and so an unstable -- but low -- vacuum reading at idle.
A vacuum gauge used to be called an "econometer" and was used under the presumption that higher vacuum translates to higher fuel economy. That's kind of true, but there's a lot more involved in fuel economy than manifold pressure.
It is however a good indicator of engine load.
Yes. In fact, manifold pressure is typically the numerical quantity that people refer to when they talk about "load."
But generally speaking, a naturally aspirated engine actually gets its best fuel economy when it's lugging -- engine speed is very low and load is very high.
ciper
Post by ciper »
What VRG3 said is pretty true. When I was in China it drove me up the fricking wall that ALL of the cab drivers do this. We would literally be in 4th gear at like 25 miles an hour moving through traffic. I bet the engines have not seen over 2500 rpm for at least 100,000 miles!
Post by 555BCTurbo »
Legacy777 wrote:It is however a good indicator of engine load.
Agreed...
It is so much easier to achieve decent fuel economy in the turbo cars with a boost/vacuum gauge...because you know right when you are going to start using a bunch of fuel (right around the 1 psi mark)
dirtyhandssubaru555
well when my car does idle i see about 15inhg. so that would meen i have a leak some were right?
86 gl hatchback rip
87 gl10 rip
Fkyx
Post by Fkyx »
vrg3 wrote:But generally speaking, a naturally aspirated engine actually gets its best fuel economy when it's lugging -- engine speed is very low and load is very high.
Wait... noob question... is it opposite for turbocharged engines?
dirtyhandssubaru555 - If the engine is idling smoothly, then you probably don't have a leak. Most likely is that your gauge is miscalibrated, but it's also possible that for some reason your engine needs more air than usual to idle and so the IAC valve is open kind of far.
Matt - No, that's a good question... Hm, well, I guess actually it would apply to turbocharged engines too, since you don't make any boost when you're lugging.
dirtyhandssubaru555
i wouldnt use idle and smooth in the same sentence when im talking about my car. would a dead injector cause low vacuum? since the car would be running on 3 cyclenders or very poor on one any way
86 gl hatchback rip
87 gl10 rip
dirtyhandssubaru555
if i should be seeing 20inhg that would meen 5inhg for each cyclender, 15inhg=one bad cyclender
86 gl hatchback rip
87 gl10 rip
I don't know if the arithmetic works that way, but, yes, anything that causes a rough idle can cause a low vacuum reading.
You can check if an injector's dead by unplugging it and starting the car. If the car runs the same without the injector as with it, that injector's not doing its job.
93Leg-c
Post by 93Leg-c »
Wouldn't that be very hard on the piston rings, cylinder walls, and spark plugs which would then make it uneconomical in the long run?
'94 TW
ciper wrote:What VRG3 said is pretty true. When I was in China it drove me up the fricking wall that ALL of the cab drivers do this. We would literally be in 4th gear at like 25 miles an hour moving through traffic. I bet the engines have not seen over 2500 rpm for at least 100,000 miles!
Yeah, Japanese taxi drivers were the same way....lugging the engine everywhere.
93Leg-c - Yeah, it's harder on the engine, and in many cars that may make it a false savings on the long haul... But our cars kinda last forever anyway.
dirtyhandssubaru555
heres what im see on my guage. 2000rpm=20inhg,1750=about 18inhg, 750 or so i see about 14inhg or less, this is all while car is parked
86 gl hatchback rip
87 gl10 rip
Is that with the engine warmed up and you using the throttle to hold those engine speeds?
dirtyhandssubaru555
yes thats with the engine warm, no im not using the throttle, 2k is about "normal" idiol for my car but it comes down slow.
86 gl hatchback rip
87 gl10 rip
Your idle must be 750-800 rpm range, or you won't get the same vacuum reading as what everyone else is stating.
What do you mean by "it comes down slow?"
Trace
Post by Trace »
sorry, Legacy777....a side question. when you state idle, is it the same as in "P" and "N" for an auto transmission? When my car is warmed up and in P position the car idles at lower than 500. it even dips down to 300 sometimes. as for N it stays at 500 rpm. is that a major problem?
dirtyhandssubaru555
when ever i start my car and step on the gas it sticks to 2k or so and comes down to 750 or so but it takes its sweat ass time. around 750-800 is see 14-13.5inhg
86 gl hatchback rip
87 gl10 rip
ciper
Post by ciper »
Trace wrote:sorry, Legacy777....a side question. when you state idle, is it the same as in "P" and "N" for an auto transmission? When my car is warmed up and in P position the car idles at lower than 500. it even dips down to 300 sometimes. as for N it stays at 500 rpm. is that a major problem?
P and N both are idle.
I doubt its idling at 3-500 hundred. Most likely you are reading the tach wrong. Look closely and you will see that the lowest line above zero actually corresponds to 500, and the second line is 750!
Fkyx
Post by Fkyx »
dirtyhandssubaru555 wrote:when ever i start my car and step on the gas it sticks to 2k or so and comes down to 750 or so but it takes its sweat ass time. around 750-800 is see 14-13.5inhg
Mine does the same thing. If I don't gas it a bit, it'll stick at 2k until it reaches about half running temp, then it'll drop to 750.
dirtyhandssubaru555
mine will do it at operating temp. might have found one source of a leek, in the 90 degree elbow were all the pcv lines connect. but they want a 100 f-ing dollars for one, i got a tube of ultra grey that cost me like 7.00, i don't know how well that stuff sets up in 30 degree and below so i have to wait till next weekend so i can use my garage cause my bro blew up his sled
86 gl hatchback rip
87 gl10 rip
