I have a 91 legacy EJ-22. Should I put a turbo on it? It has 120k miles. Will it totally rip apart my motor. I want more power!
Spence
Should I upgrade?
Should I upgrade?
Spence
91 Legacy L 4WD
Custom 2.25 Exhaust, Cone Filter
91 Legacy L 4WD
Do you have a manual or auto tranny? . Others may state whether it'll bolt up but I do know for a fact that both manual and autos in the legacy turbo are different from the normal legacy. Knowing this i'd drop in a whole engine and tranny and go from there. Also the exhaust is different and the cooling system is also more complicated and the brakes are different.
Mark,
Mark,
just buy a turbo legacy. It'll be cheaper and easier in the long run unless you are very good mechanicing and have the knowledge and time to do the work.
If you do decide to go ahead with the swap several of us are installing EJ22t motors in n/a legacy's and Impreza's. I retained the stock type transmission with a HD clutch plus extras and now have 30,000 miles on the car (a '95 Impreza) with no problems. Right now there is a swap under way in ID where we are going to run the engine with the '95 ECU in a '95 Legacy another is a EJ22t into a Brat in northern CA. If you want any help or advice just ask. If your car is in good condition a good alternative would be a aftermarket turbo. pdm turbos makes one for the 2.2 engine.
AL(CO)
al@iwtu.net
AL(CO)
al@iwtu.net
