wagon struts?
speedoboy31
wagon struts?
Post by speedoboy31 »
anyone switch wagon struts (complete) to a sedan? i know the rates are different, but way wondering what the ride height difference was. planning on taking struts/springs/mounts from a wagon to a sedan-----didn't want probs.
ciper
Post by ciper »
I thought only the spring rates were different.
speedoboy31
so, i should notice a bit stiffer in the rear,and no change in height?
ciper
Post by ciper »
Although not exactly correct yeah. The struts are what mostly determines how stiff the suspension is.
It might raise the back of your car up a small amount as well.
speedoboy31
i'm ok with a slight lift to the rear. i tend to carry a little weight back there anyways. thanks for the responses guys.
speedoboy31
the back is up a little--kind of looks like the same fender to tire clearence as the front. the ride is slightly stiffer too,but not bad.
