Help!! ROugh Idle when at running temp..
So I just did a FULL gasket rebulid on my motor..91 sport sedan..
list of things new..
Spark plugs
plug wires
coil pack
starter
fuel pump
fuel filter
SHe runs fine untill she gets to running temp, and then she starts to idle really rough and when I come to a stop..she almost dies..I cant go past 3500Rpms...
Im confused and dont no what to do..
Spark plugs
plug wires
coil pack
starter
fuel pump
fuel filter
Any check engine light? Did you change the timing belt? Maybe you forgot to plug something back in. Check if you plugged in the hose for the IAC valve to. You also say you can't go past 3500 rpm's. Were any of these issues there before the gasket rebuild? Could be a CAT. Could also be a valve.
Get a vacuum gauge hook it up to the brake booster line and see if you get over 20 something forget what they call the rating now? Usually the guage comes with instructions and tells you what level you should see for a normal engine, and says the pressure for troubleshooting. If your in the 20's its definitely a electronic issue.
Here is a site
http://www.classictruckshop.com/clubs/e ... ac/uum.htm
Here is a site
No Issues before the rebuild...I checked the valves before I put the heads on..all were good..ericem wrote:Any check engine light? Did you change the timing belt? Maybe you forgot to plug something back in. Check if you plugged in the hose for the IAC valve to. You also say you can't go past 3500 rpm's. Were any of these issues there before the gasket rebuild? Could be a CAT. Could also be a valve.
Here is a site
You sprayed the starting fluid all over? I thought I had done the starting fluid test many times over with negative results before I actually found my leaky intake manifold gasket.
Hmm. Any chance you disassembled and reassembled the IAC valve?
