Window regulator? & Front axel?
artieb
Post by artieb »
Hi, I would like to know what ussally happens to window on the drivers side, that would cause the window to tilt too far forward as its going up? It will go with some assistance? I'm guessing I have some window rollers and / or window guides worn out? I may get this road worthy before the next snowfall? Gotta RF axel to replace, also? Would just undoing the lower ball joint's pinch bolt work? Thanks again, Artie
1990 Legacy L 5-sp AWD
Bheinen74
Post by Bheinen74 »
if you are in a rustbelt, i don't recommend messing with the pinch bolt. on mine it broke even after soaking with penerating oils. (my axle was also seized into the hub. I had to get a junkyard spindle assembly, and the axle from junkyard.
I still have the old assembly (seized axle in the spindle) it wouldnt even press out......
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
