Now I've got the oil pump and front and rear seals installed.
Tomorrow I'm dropping off my flywheel to get it resurfaced before I head off to class.
*yeah, I overdid the rear main seal and had to order another one. I punched it a little too far in and covered the drain hole. And from previous threads a few of us have learned the hard way of what may happen.*
I'm going to be installing a set of HD Wiseco headgaskets and equal length headers sometime in the next week.
Stuffs I've got going on my engine.
Rebuilt pinktop injectors
Rebuilt TD04 turbo
STI Urethane Mounts
ACT Clutch/Pressure Plate
Brand New Headbolts *subaru*
A few questions...
Would you guys reccomend installing the headers before or after putting the engine under the hood.
And, I'm using a HQ Anerobic Sealer,
It only said to use "Fluid packing" behind the oil pump, but my rebuild kit came with a oil pump seal. Oh and as directed, I used a torque wrench to evenly torque down the oil pump to 4.7ft/lbs... Which isn't much, are these two things correct?
The torque sounds proper, but is the sealer right?
thanks guys/gals.
I cant wait to get it back together!
