So it happened tonight, the ABS light came on and a very audible constant hissing noise came from the ABS unit, even when the key is taken out of the ignition.
After reaching my destination and parked for 45 minutes, the noise was gone and ABS light disappeared, everything back to normal.
The constant hissing noise was a first, but the ABS light has been off and on when it snowed a couple of weeks ago. Tonight's weather condition was normal, just a bit cooler, nothing the car has never seen before.
Any ideas? Thanks in advance.
ABS Light on + Hissing noise
01 RS/94 SS
If I were to take a shot in the dark, I'd guess one of the ABS relays is sticking closed.
When the ABS light comes on the ABS computer records a trouble code (unless the light is on because the computer's failed).
Does your car have a standard transmission? If it does, you can search for a post by me on how to read ABS codes when the light is on.
If your car's an automatic, you have a newfangled ABS system that actually saves the codes even after the light goes off. I don't know much about it, but maybe this article would help:
http://endwrench.com/main.php?smPID=PHP ... &RECID=213
In any case, I would remove the ABS fuse when not diagnosing the problem, because an untrustworthy ABS system should be disabled.
