> The shape of the downpipe is critical... bit hard to describe, but
the best
> is a "bell mouth" design, that is made of two separate tube sections
> "siamese" welded together that provide smooth duct-like exits for
both the
> turbo exhaust and wastegate. Between each of these "siamese ducts",
there
> should be a short "tang" extending into the union of the two ducts
and also
> extending iand butting into the wall of the turbo exhaust outlet...
the
> purpose of which is to provide extend the separation of the turbo
and
> wastegate exhaust flows further into the downpipe and away from the
turbo.
If I were to have another downpipe built again, I would incorporate a
seperate pipe for the wastegate as you mentioned, but have it simply
point to the ground and not meet back up with the exhaust at all. A
bit loud( when the wastegate is open) and illegal, but no disturbance
to the primary exhaust at all, technically more area for the primary
exhaust to flow through, and cheaper.
-Matt
-------------------------- eGroups Sponsor -------------------------~-~>
eLerts
It's Easy. It's Fun. Best of All, it's Free!
http://click.egroups.com/1/9699/1/_/_/_/974988465/
---------------------------------------------------------------------_->
Downpipes
JohnnyG
Downpipes
Well, a compromise would be better for street use... with the waste gate
having a seperate pipe joining after at the rear of the dump pipe.
John Gillon
----- Original Message -----
To: <BC-BFLegacyWorks@egroups.com>
Sent: Friday, November 24, 2000 37 AM
Subject: [BC-BFLegacyWorks] Re: Downpipes
> the best
> both the
> there
> > should be a short "tang" extending into the union of the two ducts >
> -Matt
eLerts
http://click.egroups.com/1/9699/1/_/_/_/975144372/
John Gillon
> the best
> both the
> there
> -Matt
eLerts
