Rear Wiper ?'s
abracc
Rear Wiper ?'s
Post by abracc »
So my rear wiper does not work. No noise at all. I can't find a fuse for it nor a relay. Does anyone know where these are before I go replacing the actual motor? 93 legacy turbo wagon...Thanks!
'07 Acura TL-S
'93 Leagcy Wagon Turbo AWD
There is a relay in the rear right side strut mount. Just pop off the cover then you will see the speaker and then I think you remove the speaker and you can see the relay.
