So I cut off some sections of the plug face to allow a wrench to fit, but it's too short to get a good grip. Channel locks and vise grips can't grab it enough either.
I drilled a hole in the center of the plug and tried using an "easy out" (total oxymoron) but that broke the handle I was using to turn the east out. A bigger handle gives enough force to twist the easy out bit, but the plug still won't budge.
Anyone have tips, tricks or advice for removing this plug?
I need to get the plug out so I can put in the turbo version with a nipple. In retrospect I should have just drilled and tapped a hole in the center of the plug and fitted a nipple.
