'93 Legacy Wagon in Tacoma Pull-a-part
Doing the junkyard crawl this morning and found a fairly fresh '93 Lecacy Wagon in the Tacoma Pull-a-Part on 112th (off of Steele st).
Car is Dark Green with Grey interior, 4EAT, FWD, ABS, sunroof, roof rack. Odometer shows 217K miles. Body is really straight (much nicer than mine), glass is all there and good, and only a few parts missing right now. If I had thought to take my digi-cam I'd have posted a picture or two.
Body missing: Drivers fender, Drivers front door, and drivers corner marker light
Engine missing: water temp sensor (mine!!), MAF sensor, alternator
Interior missing: Drivers door panel , stereo. The seats (and actually all the interior) are in good shape but will need some cleaning
Not sure why it ended up in the junkyard, probably a trans problem??
Thanks for the heads up. They don't even have it on their inventory list yet, so its still fairly intact, and in pretty good overall shape.
Except, now its missing a hood, as well.
Tahiti, I didn't notice weather the antenna was still there, but its an L (i believe), so its not power.
Klaxed, I didn't take the time to check out the rear (I only needed the hood, and they were closing in ~10mins.), but I'm pretty sure the rear hatch assy. is all there and intact.
Would someone be willing to pull the wiper assembly and see if it's still working? I don't have a whole lot of time to go all the way down to Tacoma for a wiper assembly.beatersubi wrote:Tahiti, I didn't notice weather the antenna was still there, but its an L (i believe), so its not power.
Brent
'92 Legacy Wagon Winestone, 265K on body, ~100K on engine, 5spd, kyb gr2's w/ whiteline ground control springs, sti top hats, hatch spoiler to be added soon...
Damn, wish I'd seen this before I went back today. I'd have pulled it for you. I may be back over there tomorrow or Tuesday. If I get there I'll grab it for you.
INFO: coil pack, injectors, alternator, temp sensor, hood, drivers side fender and corner marker, IAC, PCV valve, MAF, and a few interior pieces are gone now. I pulled the power antenna, and the mast was already ripped out of it.
It is an LS wagon in DARK green metallic, still lots of good parts.
No rear air deflector,
It is an LS, but the antenna was broken, and I forgot to grab the wiper motor, will try again next visit. It was raining/sleeting, and cold as hell out there yesterday.
