I have a JDM WRX tranny that has an LSD Front diff, & after looking @ it I'm thinking the center diff may have been swapped out too.
Will taking off the gold cover on top of the tranny (4 x 12 or 14mm bolts) allow me to peak inside the center diff area safely?
Center Diff ID - without tearing apart the tranny?
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
I don't think it would.
I have a tranny torn apart if you want me to take a look.
Just let me know exactly what dimension you want and I'll go get it.
Rio Red '91 Legacy SS
Well, if you remove the plate you could probably kinda see the center diff, but there's a bit of stuff in the way.
I took some measurements of my center diff, then realized I only took OD measurements instead of ID..... D'oh.
