My write up on swapping a LSD in an older legacy
mellow65
Post by mellow65 »
I just did this swap and wrote down some stuff about what I did. I posted it over on USMB but I figure you legacy guys and gals would like it too because it pertains to legacys.
If this is old news just ignore it, I tried to find this kind of info when I was planning to do this but could never find it.
Have you ever wanted to add a LSD to your older legacy. Maybe to help in the slick stuff or just for some bragging rights.
Head over to your local newer salvage yard and ask a rear end out a 02+ WRX automatic wagon. Yes, you could find one from an older 2.5rs, but chances are it will have some higher miles on it a probably driven pretty hard. So why that combo you may ask. First all WRX automatics came with 4.11 gears (same as the legacys) and all came with a viscous limited slip standard. Second you need the axles from a wagon because they share the same width as the legacys, where as the sedan has a wider width. Now I’m not 100% sure you couldn’t use sedan axles, but I used wagon axles and they worked great.
The only prep you have to do to the WRX rear end is swap the input flange to the one that is from your legacy. That just takes an impact gun or a big breaker bar. Other then the flange the rear end is a strait forward swap.
The only odd thing I ran into was one axle was a little longer then the other by about a ½”. After mounting it I measured between the bearing in the hub to the rear end and the passenger side was just about a 1/2” longer. So the longer one went into the passenger side.
The main reason I went with this combo was the WRX wagons seem to be not as popular to get parts from as the sedans. I picked up my whole rear end with both axles with 8000 miles on it for $300. And I will never put the power to it that a WRX would so it should last me a good long time.
Keep in mind this will work with older legacys with 4.11 final gears or any subaru with 4.11 gears. I have heard in later years of the legacys they changed the final ratio to 3.90. So consult your manual or if it's old enough it should have the sticker on your rear differential cover what gear ratio you have.
IronMonkeyL255
Post by IronMonkeyL255 »
The sedan rear axles work as well. That's what I'm currently running in my SS.
It's the front sedan axles that are too long.
Rio Red '91 Legacy SS
mellow65
Post by mellow65 »
IronMonkeyL255 wrote:The sedan rear axles work as well. That's what I'm currently running in my SS.
thats good to know, makes spare axles easier to find
