Problem with brakes
slammedwagon
Problem with brakes
Post by slammedwagon »
Hi all,
I have a 94 legacy sw and when I go to brake theres a clunk noise in the brakes and you can feel it in the brake pedal. I have been told it could be the abs system. I could probly take out the abs fuse and itl be ok...but I really wana fix the problem so hopefully someone in here knows what Im talking about and can help me out
Cheers
86ruguy
Post by 86ruguy »
When you say there is a "clunk" noise, is it coming from outside the cabin or under the dash or what.
I had a clunk noise for a while and figured out that it was worn out caliper slide bolts.
Hope this helps and good luck.
D
92wagon (wife's)
92 sedan (sold)
91 ss no mods (sold)
88 GL Wagon (broken)
slammedwagon
hi it sounds like outside the cabin. itl only make the noise while coming to a stop after driving over 20-30kms, right before you come to a complete stop.
subytech
Post by subytech »
How loud is the noise
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
