4eat to 5mt swap
Carbix
4eat to 5mt swap
Post by Carbix »
on the electrical end of the swap is there anything i need to do.
revers lights?
park and nutral to start?
cruise control?
i have read up on lots of threads im just trying to see if anyone has new ideas or if there is something i missed(as im sure there is lots) :-D
|====.[Legacy. Central].====|
|=+[Leaving A True Legacy]+=|
Have you read my write-up? Everything is there you need to do.
The only big exceptions you'll run into are swapping out the speed sensor for the cable type, and the starter bolt issue with the newer style transmissions.
