Odd AFR
Odd AFR
So my car was running great tonight.
I came home for a bit and then left.
As I was leaving I looked at my narrow band and it was reading extremely lean at idle and then when I full on gas it it says I'm running extremely rich.
Now, I know it's a narrow band so I can't have complete faith in it, but usually when I floor it I'm "stoich" (right between lean and rich).
So what would cause me to all of a sudden be running extremely rich at full boost and extremely lean at idle?
Sounds to me like something's wrong with your oxygen sensor or its wiring.
At idle the signal should be constantly changing, moving back and forth from lean to rich and back.
At full boost, it should be rich.
Also, a near-stoichiometric ratio on full boost can be dangerous to the engine, so I hope it was misreading before somehow.
Arctic Assassian
Ok. Thanks for the tips guys. I'm that worried about it running rich on boost. Lol.
But I started it up this morning to head to work and it would barely idle like I kept blipping the throttle because it sounded like it was about to die. Once it was warmed up everything was fine. It did this on my way back home from work, too.
So disconnect the O2 sensor harness and then unplug the battery from the car for 30 minutes or what ever to reset the ECU.
Reattach the battery and start the car WITHOUT the O2 sensor plugged in? Correct?
Ok. So if I do this test and it shows that the O2 sensor is the problem, I should still replace it correct?
I'm just trying to understand the purpose of the sensor now if you say that you can drive around without it...
Oh yeah that's a problem I was having, also. I was on my way up to Crystal Mt. and my CEL came on but disappeared after about a minute or two. Then it would come back 20 minutes later. It never came on during the drive back.
Could this also be related to the O2 sensor?
Well I checked my ECU codes, even though I don't have a CEL...yet.
It threw a 21 and a 32.
21 is for the water temp. sensor. I think that was just an old stored code because I had a problem with it before and now it's fixed.
The 32 is for the O2 sensor. Maybe it's from when I got a CEL on the highway?
I unplugged the O2 sensor and tried driving around without it, it was still pretty crappy. I've checked for any disconnected vacuum hoses but haven't found any.
So I'm still thinking the O2 sensor is the problem. Agreed?
I keep thinking that maybe I have a vacuum leak, but that would mean that I would have a rough idle ALL the time, right? I only get a rough idle when the car is warming up. Then it seems to run fine, but really rich...
Oh and as of the past two fuel tank fill ups, I'm getting about 18-20 MPG...
douglas vincent
If you are running an O2 sensor through anything besides your
ecuu, do'tr belive it.
You NEED to have an external wideband reader to have good returns.
Haha ok. I was going to pick up an AEM wide band with my next paycheck.douglas vincent wrote:If you are running an O2 sensor through anything besides your
P.S. Were you drinking or was that just a typo? hahaha
VIKASH I LOVE YOU (and I mean that in the least gay way possible)!!
I went to the Subie dealer today and got my O2 sensor. The car runs better than when I first got it! It's great. Hahaha.
Oh and the guy at the dealer said it was going to come out to $148.00 so I told him I'd like the one for the N/A Legacy and it was only $99.00. Hahaha apparently it costs them an extra $49.00 to shorten the wires on the same O2 sensor...
Arctic Assassian
